A problem of weight
Gestartet von mistyoptic
1 Antworty 2 gefällts 0 Follower Letzte Aktivität: vor 5 Jahren
A problem of weight
Hi Geoff,
I might be wrong but if the drawings are from 1952 then i would imagine the weight would be lbs/oz.
As we would of used imperial measurements back then in the U.K..
Gefällt von scout13
A problem of weight
Those that are following my blog on building the Dutch Auxiliary will know that I am working from a rather sketchy plan from 1952. When it comes to the amount of keel weight required the plan gives no indication as to what it should be. lbs/kg Perhaps someone could give me a sensible starting point for the hull which is 16 inches by 7 max beam (410x 189mm) All answers on a postcard or here on the site. Many thanks Geoff.
Geoff L.
Gefällt von Martin555
