Acceptable Rudder Movement
Gestartet von Ronald
6 Antworties 5 gefällts Letzte Aktivität: vor 5 Jahren
Hi Ron wonderful area at Balsam Lake .Camped up there many years ago.You are so lucky to have a body of water so good for launching your boats.
Rick
Ron,
Have you got servo end limiters on your Transmitter.
If so it might be worth looking at the settings.
Loaded the Escape and heading to Balsam Lake with two sailboats and three powered. Will get back to you later. Yes my wife will take pictures and video.
Gefällt von Martin555
My Ville Class tug is at 22 degrees. I do not know if it is the Servo that limits rudder movement to more or something else? I have tried several linkage positions on the control horns both at Servo and rudder.
I use two control rods, and checking for freedom of movement before connecting to Servo arm, there is lots of freedom.
Still needs to be launched to know how it handles.
Hi Ron,
After a quick around i found this.
Why Rudder Angle Limited to 35 Degrees ? Beyond 35 degree rudder efficiency is reduced due to formation of eddies on the back of rudder as the flow is no longer streamlined. ... The manoeuvrability does not increase beyond 35 degree, but rudder torque increases and ship's turning circle increases.
Gefällt von jacko
What is the minimum rudder movement? Maximum? Acceptable? In degrees...
